8 members (2-Ton, Nick in Manitou, GMCJammer51, Joe H, Andrew_Julio, Jay R, 68ironhead, 1 invisible),
90
3
Mod | | | Forums66 Topics128,169 Posts1,057,033 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 153 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 153 | Here's what I have discovered so far:
1. Due to my careless assembly of the carb during rebuild, the idling jet wasn't tightened down all the way to contact the jet calibration seat. That couldn't have helped the idling any. No sign of blockage in the fuel passages.
2. The idling mixture screw supplied with the rebuild kit didn't have the exact same profile as the old one that I took out. The new one wouldn't screw in as far. I put the old one back in.
3. The pump piston supplied with the rebuild kit with some sort of plastic diaphragm on it stuck in the well and wouldn't depress. Hence, no functioning accelerating system. Maybe the ethanol in modern gas caused it to stick, maybe it's just old. The kit came with directions to rebuild a 1974 Opel. I still have the old metal pump piston that I have epoxied onto a new pump rod. Same overall length as the original.
I don't know yet that these modifications will fix all of the issues with this carb, but I doubt that it will run worse. I haven't had a chance to test drive yet but I will report back. For the record, this was a Walker rebuild kit from Carburetor Factory. I'm not sure that I'd buy another one from them.
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
