I looked, and could not find one for my 47 1.5 ton. I made a flat aluminium plate that fits as tight as possible around the lever and release rod, and placed it under the carpet so it slides back and forth with the lever. It works well as a seal and doesnt interfere. I cut a slit in the carpet just big enough for the lever and its movement.
