8 members (Maybellene, tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible),
198
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Cab corner & rockers are best to be bought, the time you will spend making cab corners is not worth it. the floor you may be able to fab, all depends on how flat it is. I replace a couple of cab corners about a month ago for a friends GMC and only took an hour or so to remove the two cab corners with a grinder & cutoff disk and mig weld them into place and a skim coat of filler over the welds | | |
