| | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The outside door lock is all contained in the handle itself on '53 doors ('52-66 also). Turned to the lock position you cannot push the button. There is a piece with a slotted hole in the assembly and a shaft protruding through it. In locked position the shaft won't go through the slot. In unlocked it will. There is nothing that will be changed when installing in the doors.
Carl, what is "The rod which goes between the key slot and the lock mechanism..." referring to? | | |
