| | | Forums66 Topics128,114 Posts1,056,605 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 35 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 35 | Trying to remove my 35 truck trans. Have installed upper slide bolts and trans slid one to two inches out and dead stopped like it's hung up on something. Not hung up on anything I can see. Not hitting frame. Reason I'm removing is the throw out bearing looks like it came detached and is loose and not engaged in the pressure plate. Can't see any hang up there either. What the check am I missing???? | | | |
Entire Thread
can't remove 35 truck transmission
| 35truck | 07/31/2015 10:00 PM | |
