I will have to check the lights to see which ones are flashing... right now I have all the fenders off and the bed, so lights are all disconnected. It appears that it is the hazards (so all; both sides, front and rear) are flashing.
The weird thing is that before I took everything apart the blinkers, hazards and turn signal switch worked fine. I didn't mess with anything (that I know of) so I am puzzled as to why all of a sudden it is acting up.
Thank you!
