11 members (Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, 52Carl, fonz8261, greenie-reddy, Forty9, RoadsScholar, 1 invisible),
127
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | I don't have the original line. What I have is a Rub Goldberg that was done by a PO. I want it routed via the correct routing from the '46 period. Someone must have that routing info somewhere.
I purchased a correctly routed S/S fuel line from Jim Carter and need the companion vacuum line which runs with it and is clamped together.
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | |
