Mine doesn't have any stamping on the distributor pad either Jerry. Its a replacement engine and was made in 1964. When I got it, it had the dowel OUT meaning it was set up for no filter or a bypass filter. You can read alot about your engine here:
http://devestechnet.com/Home/TheVenerable261
Its nice if its equipped for a full flow system to use it. It will make the engine last longer. It sure looks nice!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
