| | | Forums66 Topics128,056 Posts1,055,804 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | I am having trouble following what you are asking. -you have a '53 3600. Is the 52 axle above the springs? -you have a '66 1/2 ton rear end which you would like to use. I don't understand what the PO did or why. That doesn't really matter. What does matter is that you put the '66 axle on the same side of the springs (above or below) as what was original. You will need welded-on spring perches which are the same width as the springs and 3 inch radius u-bolts, and a plate with holes in the right places. Carl
