| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | Going to swap the 66 1/2 ton rear end in on my 52 3600. From what I'm seeing on LMC and the shop manual, there aren't any spring perches. However, the PO had tried to flip the rear to lower it and had welded perches on the under side. I still have the original anchor plates and look as if they will fit on the 66 as well since both rear ends measure 3" around. So my question is: will I need to buy some perches and weld them on or not? | | |
