1 members (Danielbolt),
164
3
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Try filing the top of the key a little to keep it from dragging on the gear hub. The key is more of an alignment device than an actual drive lug- - - -the press fit carries most of the driving load, so the key does not have to be a perfect fit in the slot. Also, a little anti-seize compound on the parts will help them slip over each other without compromising the fit. An aluminum gear can be heated to about 250 degrees and it will virtually fall into place- - - -I don't think I'd try that with a fiber gear, however. Jerry
