| | | Forums66 Topics128,108 Posts1,056,566 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11116 11/04/2003 5:03 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | The key to distributor swaps is to use a distributor with the correct diameter shaft for the oil pump drive. Also pay attention to the thrust load on the distributor, if the dist body or oil pump body is supposed to take the end thrust. Make sure the dist gear is in good shape and not crammed down on the oil pump. Use layout dye to check fitment of gears.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
