I use the WalMart brand of flat - just $.99 Like Marko said, a very light dusting is good enough. You can remove too much primer in surrounding areas if the guide coat is too thick.
Good Luck
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
