There are several good articles on this swap one of which is posted under the "TECH TIPS" section at the top of this sites page.
The other good info is from Patrick's Antique Cars and Trucks.
http://www.patricksantiquecars.com/articles.html
Read on line or request their catalog as it has good info.
In short terms though it is not a unbolt, move, and drop in with a simple bolt back up.
But the swap is much simpler then say adding a V8. I am swapping a 235 into my 48 in place of a 216 that is bad and to me the hardest part is just pulling the engine.
Points of difference that need attention will be front mounting holes (two need drilled most likely), flywheel and bell housing swap, and 6v 12v.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
