Did you replace one ignition wire at a time or did you just take all of the old ignition wires off all at the same time?
You could have your firing order messed up.
How and where are you checking for spark? Ignition wires at the plug end?
Coil wire at the cap end?
No mention of condenser in your post. A bad condenser and you will not get a spark. Condenser was new does not mean new condenser can not be bad out of the box.
Point gap setting is?
