1 members (Hanks custodian),
264
3
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If your clutch were slipping you would know it when you take off from a standstill, or smell it or it would be chattering when you slip it.
We get so used to hearing our modern engines running at 1800 rpm at highway speeds in our sound proof cocoons that a stovebolt at 3000 rpm sounds like its gonna fly apart. As I said, it won't, if it's a healthy engine and not all worn out. Remember to, that brand new these only were putting out a hundred or less HP. Even the modern four cylinder engines are pumping out a couple hundred horses and the body's are much more aerodynamic than a barn door, which is what your old truck is second cousin to. dg
Denny G Sandwich, IL
Entire Thread
SM420 4 speed, speed.
| helitack32f1 | 06/20/2015 6:34 AM |
Re: SM420 4 speed, speed.
| crenwelge | 06/20/2015 6:52 AM |
| 52_Ton | 06/20/2015 11:31 AM |
| Denny Graham | 06/20/2015 11:44 AM |
| truckernix | 06/20/2015 2:19 PM |
| alltruck72 | 06/20/2015 3:05 PM |
| Denny Graham | 06/21/2015 2:03 AM |
| Deve | 06/21/2015 3:05 AM |
| helitack32f1 | 06/21/2015 6:33 AM |
| Denny Graham | 06/21/2015 10:05 AM |
| helitack32f1 | 06/27/2015 8:09 AM |
| Dusty | 06/21/2015 10:42 AM |
| 52_Ton | 06/21/2015 11:35 AM |
| truckernix | 06/21/2015 12:21 PM |
| Denny Graham | 06/21/2015 2:01 PM |
| Harold46 | 06/21/2015 2:30 PM |
| Denny Graham | 06/21/2015 2:54 PM |
| steve sr | 06/21/2015 4:40 PM |
| Pre '68 Dave | 06/21/2015 4:57 PM |
| steve sr | 06/21/2015 5:22 PM |
| twotone | 06/22/2015 3:02 PM |
| 54Belair | 06/22/2015 11:08 PM |
| oldbluetruck | 06/23/2015 7:00 PM |
| 32vld | 06/27/2015 1:09 PM |
| helitack32f1 | 07/11/2015 9:37 AM |
| '49 4400 | 07/19/2015 6:39 PM | |
