Guys, really you should not need to reduce more than the mixing ratio calls for. If you do, only about 10% MAX more. You really need to set up the gun properly and have enough air. Any more solvent is simply a band aid.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
