8 members (TexasA&M48Truck, Peggy M, 1955 1 Series, CuzzFuzz, greenie-reddy, Forty9, Hotrod Lincoln, thekid1950),
50
Mod | | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,744 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,744 | 265's were notorious for piston failures. The skirt would crack away from the invar strut that limited expansion from heat, and produce a knock at idle and part throttle. Unless you're doing a period-correct restoration or have some other reason to retain an "original" engine, a later model, larger engine such as a 283 or a 305 would probably be a better choice. Virtually all the small block V8's from the late 50's through the early 90's would be a bolt-in swap with the 265. Jerry
