11 members (Peggy M, klhansen, Wayne67vert, 52Carl, Hotrod Lincoln, Forty9, walter74, HandyAndy, cmayna, 55shaker, TPR57C),
138
3
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11077 05/17/2004 3:24 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I think your fuel line should be 5/16 inch steel tubing. You could also have a bottleneck at the tank outlet where scale, varnish, rust, and crud tends to cluster. A good test: Rock the truck from side to side to spread around the imagined junk. If this results in improved performance, time to pull and boil out the fuel tank. Do you have a good inline fuel filter? That, plus a new fuel line (copper is not a safe material), and a tank boilout would help a lot. Find a local radiator shop that does fuel tanks, it is a good investment.  | | |
