8 members (cmayna, 5 Window 9434, Opelika Tom, TooMany2count, Otto Skorzeny, JW51, Gib70, mk72),
84
2
Mod | | | Forums66 Topics128,053 Posts1,055,776 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Pressure testing oil galleries is a difficult, complicated process and is usually done on a bare block after a thorough cleaning. It's necessary to plug as many leak points as possible, such as main bearing oil holes, etc. I use a piece of gasket material sandwiched between the crankshaft main bearing journals and the block and a few other sneaky tricks, then apply 50-75 PSI air pressure to the system, fill the block with water, and look/listen for leaks in the cooling passages. I don't know of a simpler method to find that kind of a leak. Jerry
