| | | Forums66 Topics128,163 Posts1,056,920 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Using a 1938-47 truck bellhousing will allow you to use the original trans and clutch/brake mount. Using a later bellhousing opens a can of worms. Timing plate will most likely need drilling for front mount. Water pump will need attention.
See the USA in your vintage Chevrolet! My Blog | | |
