If the core support has to be raise to much to get the hood to
fit the cowl correctly, you might look at the rear of the cab
to see where it's setting. By shimming the rear cab mounts or
reducing the front mount thickness you can bring the core
support down to where it should be, that is with about a 1/4"
rubber shim and one or two thin metal shims.
dg
Denny G
Sandwich, IL
