1 members (1955 1 Series),
99
Mod | | | Forums66 Topics128,268 Posts1,058,396 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11056 08/26/2004 4:59 AM | Joined: Sep 2003 Posts: 42 Junior Member | | Junior Member Joined: Sep 2003 Posts: 42 | I was having some problems with my starter engauging into the flywheel.
I was scraping off the mud, crud and road tar off the under side last night, so I took off the flywheel inspection cover and I saw where I have a few rounded teeth on the ring gear. Thus causing the starter to grind.
Assuming this ring gear is heat shrunk onto the flywheel. Can I remove the ring gear and flip it around and use the other side of the teeth. OR just by a new ring gear. If I need to completely replace the ring gear how do I go about ordering one? Knowing the are "XX" amount of teeth on the ring gear since I am using a 6 volt starter, with 12 volts(don't know if that matters or not)
I was thinking that that on a 12 volt starter there are so many teeth and then there are so many teeth on a 6 starter. OR maybe it was the starter bendix. I really can't remember what I was told.
ANYHOW, where do I find a new flywheel ring gear, if I need to buy one?
I am getting ready to replace the clutch, pressure plate and throwout bearing and of course resurface the flywheel, before winter gets here.
1954 Chevrolet 3800 series flatbed dump
