| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0002.htmA truck in my area would almost never need the diluted SAE 10 oil that GM recommended. If you do not drive in the winter (to avoid salted roads), a 15W-40 (or, a 10W-30) will do no harm and will be closer to GM spec. " . . From the factory trucks came with SAE 10W.. "Whatever weight oil GM put in at the factory, the factory oil was considered to be "break-in" oil (by GM) - it was supposed to be changed after 500 miles. | | |
