The truck is a 1955 3/4 ton truck
The motor is a 1974 Buick Big Block 455 with th400 trans out of a 225
Where do I start on how to put these two together?
I figured the 3/4 ton needed some pulling torque and the buick motor doesn't weigh that much more then the chevy small block
I am also pulling as much as I can from the buick car. Ilike the radiator which has the trans cooler installed with it.
