7 members (Gdads51, Wheelie, 55shaker, baldeagle, Otto Skorzeny, ShopRag, 1 invisible),
102
3
Mod | | | Forums66 Topics128,268 Posts1,058,384 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | If the throttle shaft is worn, bushings can help and possibly help the high idle. As the engine is running, wiggle the shaft and see if that makes a difference. I fixed mine with a sliver of brass sheet bought from a hobby store. You can usually get them in as assortment pack. I took the throttle plate (butterfly) off and removed the shaft and wrapped the brass around the shaft and worked it back into position. With trial and error you can find the right size. | | |
