7 members (MRMEROTH11, Wickedbass, GradyB, SWEET, TexasJim50, klhansen, 1 invisible),
68
2
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11043 07/19/2004 4:44 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Answer to #1 from personal experience- I'd soak it overnight with Safety-Kleen then shake the crud out of it.
Answer to #2- Check the "Links" page of this site for vendors then check their on-line catalogs.
Answer to #3 from Motors Truck Repair Manual- Flywheel to crankshaft 50-65 ft. lbs.
Answer to #4 from personal experience- The bolt holes only allow the flywheel to fit on the right way.
Answer to #5 from personal experience- J-B weld should work fine. | | |
