| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The amprage goes UP as the voltage goes DOWN...so using a 12 volt switch on a 6 volt motor is a bad thing. Your new switch may be rated at 15 amps and your 6v motor may be pulling 20 amps or more which would be a fire hazard. Mike B  | | |
