You'll find that the 2wd version will be too narrow. One from a 4x4 would be better, and one from a 4x4 with the Wide Stance option (ZR-2) would be ideal. If you can find a late version, '98-'04, with the ZR-2 option, they not only come with rear disk brakes, but are also a narrower version of the full size truck 8.5" ring gear 10 bolt.
Bill Burmeister
