| | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Yep that is the same cam (if the duration #s are 194I/204E @ .050). I have a 500 cfm 4 barrel with the settings unchanged out of the box and the response is crisp. No bogs and no hesitation. My idle is smooth, no lope. How's yours?
You will never turn good quarter mile numbers with a highway rear end. If you want to improve #s then a 3.73 (better yet, a 4.11) or lower is what you'll need. What I like most about my setup is that I keep my stock lower geared rear end for great takeoff acceleration, but run a 2.75 final overall ratio in overdrive. Turning 2200 rpms (literally cruising) at 70 mph is great.
-ftyler | | |
