Really didn't want to go and disturb something that was working fine in the first place, was just asking since I was planning on replacing this motor anyways and trying to straighten things up and make them right as I go along. From what I can gather by reading offset engine installation on the internet as long as it was done right with no vibrations felt while driving it should be good as is. Also I have a question, it has the front engine mount with a rear cross member mount holding the rear of the transmission with no other anchor point in between. Will this put undo stress where the bell housing bolts to the engine and where the flywheel bolts to torque converter as these are the only two areas holding the engine and transmission together right? Just seems like there should be something else in the middle to hold and support it. Thanks HUGH
