8 members (Otto Skorzeny, MikeE, Wickedbass, MNSmith, 2-Ton, JW51, Maybellene, 1 invisible),
74
2
Mod | | | Forums66 Topics128,042 Posts1,055,597 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | About to put my head on and I have a couple questions. 1. I noticed on the driver side near the front of block that the gasket blocks 2 coolant passages. (Not the steam holes) Why? The old gasket is the same. Curious as to why these 2 holes to the head(848) from the block would be blocked off. 2. Should I use a sealant on the gasket? It doesn't say whether to or not. It is a fibrous one with steel/copper rings. Head and block are flat, clean and ready to go. Thanks bolters. | | |
