There is a round rubber plug on the floor on the drivers side. Pull that plug up & the MC reservoir is under there. Fill it with fluid & pump it a few times. Use DOT 3 brake fluid. The pedal should pump up. Then like the guys said crawl around under the truck & look for wet areas. Watch the bottom of the brake backing plates for fluid running out which will indicate leaking wheel cyls.
