Hy Pakrat48, try removing the wire from the sending terminal of the gauge and with a jumper wire touch a known good ground for a few seconds and see how it affects the gauge reading. The gauge operates by varying the strength of two magnetic fields in the gauge, at the moment it would appear that only one field is energized in your gauge. It could be that you have a bad ground or open circuit to your fuel tank sending unit, hope that helps.
