| | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There was a change in pans between 1954 and 1955 on car engines and first series 55 and second series 55 in trucks. I suspect the date code of your block will be late 54, and was actually installed in a 1955 car. Another possibility is that it was a crate engine sold much later. I have seen these. They look like 54 engines but use the later pan style. Does yours have a single large hole in the block for the water pump or two smaller?
See the USA in your vintage Chevrolet! My Blog | | |
