| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | There is a 3/8" pipe tap available, but there might be another approach possible. Get a short 1/4" NPT brass pipe nipple (3/4"-1" long) and thread it into the carb housing with some red Loctite or Marine Tex sealer, then add a 1/4" pipe coupling to thread the inverted flare adapter into. The tapered thread on the pipe nipple should allow you to run it deeper into the carb body than the shoulder on the adapter will allow. It will look a little goofy, but it will probably solve the leak without having to replace the carb. Jerry
Entire Thread
Stripped (loose) threads, carburetor fuel inlet
| bajones238 | 04/17/2015 1:24 PM |
Re: Stripped (loose) threads, carburetor fuel inlet
| Joe H | 04/17/2015 2:49 PM |
| TooMany2count | 04/17/2015 3:41 PM |
| Hotrod Lincoln | 04/17/2015 3:55 PM |
| bajones238 | 04/17/2015 4:55 PM |
| Hotrod Lincoln | 04/17/2015 5:24 PM |
| bajones238 | 04/17/2015 6:04 PM |
| LONGBOX55 | 04/17/2015 7:31 PM |
| Paul_WNC | 04/17/2015 9:47 PM |
| bajones238 | 04/17/2015 9:51 PM |
| David Bush | 04/20/2015 4:08 PM |
| LONGBOX55 | 04/20/2015 10:19 PM |
| DADS50 | 04/20/2015 11:41 PM | |
