| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | You haven't mentioned what carburetor you're working with. If it's got a pipe thread and an adapter fitting for the fuel line you can drill and tap the carb body for a reducer bushing and go to the next size larger pipe thread. The Quadrajet-type inlet fitting that also serves as a filter housing is available in an oversize-thread, self tapping version. I've never found a "thread restorer" compound that works well on fuel inlet fittings. Jerry
Entire Thread
Stripped (loose) threads, carburetor fuel inlet
| bajones238 | 04/17/2015 1:24 PM |
Re: Stripped (loose) threads, carburetor fuel inlet
| Joe H | 04/17/2015 2:49 PM |
| TooMany2count | 04/17/2015 3:41 PM |
| Hotrod Lincoln | 04/17/2015 3:55 PM |
| bajones238 | 04/17/2015 4:55 PM |
| Hotrod Lincoln | 04/17/2015 5:24 PM |
| bajones238 | 04/17/2015 6:04 PM |
| LONGBOX55 | 04/17/2015 7:31 PM |
| Paul_WNC | 04/17/2015 9:47 PM |
| bajones238 | 04/17/2015 9:51 PM |
| David Bush | 04/20/2015 4:08 PM |
| LONGBOX55 | 04/20/2015 10:19 PM |
| DADS50 | 04/20/2015 11:41 PM | |
