it's a sweet ride. a 292 clifford intake, water heated, split 2 to 2 exhaust to a single walker muffler and single exh. LOADS of torque
the thing is about doing any ONE thing
you can't............... it's a combination of components that work together to make the whole system function.
i'm not sure what you mean by this
if you're asking will a 292 intake fit or is the same as a 235 the answer is yes. ALL inline 6's are the same length. the block are the same length, the 292 is 1.75'' taller.
http://i67.photobucket.com/albums/h298/1951otter/22A-1.jpg
