Hy trump, did your rear axle have removable covers on the center of the hubs? Did you find an axle under those covers, did the axle have external teeth on it which engaged internal teeth on the hub? If that is the way your rear axle is setup then there should be a tapped hole in the center of the axle I think it is a fine thread probably 7/16", you can put a bolt through the end link of a length of chain and screw it into the axle, then if you whip the chain the axle the should come out. Be careful there shouldn't be a lot holding it in there, good luck
