0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | My 12v Heater switch looks like the pics from post# 838739 which I helped me wire so thanks DAD50/Gus. https://picasaweb.google.com/103098517476416596131/UntitledAlbum15#5582269469555317746 I think I have a problem with a backwards/bad 3 speed switch. First click right starts the switch on High, then Med then far right is Low. Seems like the first click should be Low - Med -High like most. Does anyone else have this problem? I cannot change the internals on the switch and I think another switch in order. Stress on the squirrel cage is pretty dramatic with a loud “thunk” when started. Any ideas would be appreciated but I will not be ordering this same type of switch if this is "normal" Thanks Kevin - 1952 Chev 235.
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | |
