Originally Posted by truckernix
So I would interpret that response to mean that you won't get your money back if it doesn't work out. In general, there is usually some extra work or fabrication involved in installing one of those. Your truck MC would have a different diameter than the 1/2 Ton. Somebody may be worried about the stroke volume.
You may be right on track with that.
1953 3800 Dually Flatbed
