Thanks for info.
Bartamos, you are correct, the spring seems to be just for holding the flap in whatever position you want.
I still don't know how to get the shaft out. should i just try and clean it up and put it back together, or try and replace the shaft?
here is a picture of the shaft
Alec
51 Chevy 3100
