| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The main thing to look out for is to make sure the doors still fit after you do all your adjustments. Fit the doors, then brace the cab by tacking braces across the doorways before you take the bottom off the cab. That should keep the doorways square so you can fit the doors back up when you put the cab back on the frame.
