Well, if it is the complete front floor pans, then you have to consider the surrounding metal. There are cross member peices attached underneath that hold the front cab mounts, rockerpanels, toe board and inner kick panels. That is the short list. I am doing the complete list so that is how I can remember!
1951 1 Ton Completed
