| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Run a loop of heater hose between the two ports- - - -it will provide circulation of coolant from the head back to the water pump and prevent hot spots from developing around the cylinders. Once the stat opens the majority of the coolant flow will follow the larger radiator hoses and minimize the bypass flow. Jerry
