Originally Posted by The Hill Boys
Jim, I order this part as what I thought was needed to go from the emergency brake pedal to the cross member.
(47-54) Emergency Brake Control Rod
I thought then that a cable when from each side of the cross member to the rear wheel. I order these assuming that is what made the connection of one end of the cable to the cross member.
Ryan and I started messing around with the forward part of the emergency/parking brake rod as shown in the link above. What is the little "hook" thing at the bottom of the picture? Is it just a spring puller?
Ron and Ryan Hill
1952 Chevy 3100
