| | | Forums66 Topics128,284 Posts1,058,532 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | Always test your welder on a p[piece of scrap the same as what you want to weld. Mig welders will change from day to day depending on humidy ect. here is a web site that will go over the basic things with mig welding http://www.nanungtinda.com/Car/gh1.htm Practice a little bit before you weld on you patch and you will do it with no problem.
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
