2 members (TUTS 59, 1 invisible),
192
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | Is the cylinder head off? If so, it can be magnafluxed or pressure tested for cracks. If not, splice the coolant inlet and outlet hoses together and pressurize the water jacket, then look for leaks. DO NOT pressurize the radiator- - - -that old one will blow out long before there's enough pressure to show up a leaky head or block! Jerry
