| | | Forums66 Topics128,081 Posts1,056,074 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The problem is the offset in the backing plates. Even if you remove the backing plates the mounting flange welded to the housing is in a different position.
See the USA in your vintage Chevrolet! My Blog | | |
