You've been around here as long as I have and from your
pictures It's apparent that you're no stranger to the business
end of a wrench. Why not just buy the parts and rebuild it
your self? Everything is available, bearings, seals, gaskets
including a new worm gear assembly if you need that.
The stock steering box is more than adequate for the job and
if they've lasted 60-70 years in service, your rebuilt one
is gonna out last you a couple of times over.
dg
There is
